Daz3D to CC UV Transfer Tool
UV Transfer tool lets you directly bring in Daz3D’s G3, G8 skin content like makeup, tattoo to Character Creator, without going through CC Transformer’s long character transfer process. You can only choose the required texture area, it greatly saves the texture conversion time.
Stack Makeup with SkinGen Layers
Contents transferred from Daz3D G3, G8 series can also be saved with assigned SkinGen categories such like lips or eye makeup. you can adjust its color, transformation, materials, and use different blend mode with other skin layers.
Seamless Across Materials
Due to the UV difference between Daz3D and Character Creator, a brought in tattoo pattern might sit across several UV areas. SkinGen’s new cross-UV texture baking design keeps the seamless connection over brought in textures.
