My Issue
My Vote
My Comment
My Subscription
Submit
Votes
0
Product:
Character Creator 3
Version:
3.31
Status:
Released in 3.4
Issue 7243
(Retopologize Base for High-Poly Normal Bake ) feature changes the pose
Steps to reproduce the issue:
1. follow the tutorial from the lower link to retopologizing a low poly mesh and creating a high poly mesh.
Link:
https://manual.reallusion.com/Character_Creator_3/ENU/3/Content/Character_Creator_3/3.3/09_Transformer/Importing-HD-DAZ-Characters.htm
2. then instead of baking them, reimport both mesh obj files into 3d program and check them.
3. keep active both objects into the viewport and see.
4. you will find that Character Creator changed the pose a bit.
Actual Result:
Pose changes when you retopologize using Character Creator 3.
Expected result:
It should be the same as before.
OS: Windows 10
0
2539
Bug
Suggestion
General
Pipeline (Export/Import)
Pipeline Extension
Submitted by
mibtesamsadiq
2020/09/08 19:35:23
COMMENTS (0)
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
Do you want to delete this issue?
