The Substance Designer 5 + Substance Power 200 install I installed iClone v6.53 Pro Trial while awainting iClone 7 I installed Substance Designer 5 by following their instructions and became a member on Allegorithmic in order to set register key and the program installed. However when I tried to install the Substance Power 200 or the Substance Tools by the Install.RDL I get the pop up box showing: Reallusion Content Downloader
Cannot find the program associated with the downloaded file(s).
Please install iClone first
are there issues with having the trial verson or something else
OS: Windows 10
3138
Submitted bydarbeck
COMMENTS (1)
You can't install purchased content with the Trial version - you need to buy the full version of the software.
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
